I got half of them in place. Just set in place and the weight put back down. I noticed a few things. On the inner bed mounts, the poly kit comes with some big washers to go on top of the top bushing, between the bushing and the bed. Thing is, it's right against the bed, and the hole in the washer is round and too small for the square part of a carriage bolt to fit. I'll probably go with hex all around, but did anyone else run into this? If I wanted to keep the hex, I guess I'd have to open up the washer opening.
The other thing is what to do with that bracket thing near the rear most mount. I don't think the bottom bushing will fit in it the way the factory one did. I could just push it forward out of the way, but I don't really see any way to get it out of the frame without dropping the tank. How did everyone deal with this? rebelgregory, you say you cut it down, I assume you didn't do that with it still in the frame?
Damn I've got a bad memory
