What's the going price for a stock 69?
Also, the interior panels appear to be the "scroll pattern" which I believe was a CST option, and I'm not sure they were available in 1969. :thinking:
-G
Yep, I have the scroll on all panels. She was a CST, too.
The wear on the door jams from a driver getting in and out looks far more than 7,000 miles worth. I bet that odometer has been around once, but probably not more.
GOOD CALL and GOOD EYE - You could not wear the paint off the inside of the rocker with 7300 miles. That does not add up.
neither does the wear on the inside bed and that is a fairly substantial bash in the rear. Hard to believe all that happened in 7000 miles and nothing was ever done to it.
That said, it is a very, very nice example of a clean Blazer. As far as value goes, none of it matters unless all the numbers match and that would verify whether it is all original or not. That may not be the original engine and if that is the case who knows how many times that odometer has flipped....and how do you know it is the original odometer?
It's a nice enough example that I would ask 15K as it is. Not a lot to do to completely restore it.
