what is the puck for in this pick? is it the same diameter and thickness as the hole in the arm? if so why cut it out? is it solid or does it have a hole threw it? can anyone give me the distances from the centerof the king pin hole to the center of the hole for the tie rod end? also cand anyone give me the distance for the other rod end for a high steer setup
http://www.rockequipment.com/images/d60arm1.JPG
