whats the puck
T_Spurger
Texas
what is the puck for in this pick? is it the same diameter and thickness as the hole in the arm? if so why cut it out? is it solid or does it have a hole threw it? can anyone give me the distances from the centerof the king pin hole to the center of the hole for the tie rod end? also cand anyone give me the distance for the other rod end for a high steer setup
http://www.rockequipment.com/images/d60arm1.JPG
uhh,..i think they just showin' you the materal they removed...so you know its machined from solid bar stock(billit) and not cast and machined out...nice looking arms
i've been wrong b4....but, some1 will correct me if i'm wrong...so
the measurements you seek, iirc, they can vary...kingpin/tre..can vary slightly depending on manufacturer of arm, and i believe you can get them different lengths by getting custom arms, they even have them to put the draglink/connecting rod behind the kingpin , the arm to arm tre's length can vary from truck to truck depending on frontend alignment...if these are exact measurements and there are exact lengths, please post up!
i think those do go back into there... they're for the king pin....i believe your stock cap bolts on the top of that style and those pucks go back in above/below the spring to make up for how much taller it is. just like the ones on the raised D60 block for the king pin cap. im pretty sure that's how it is. but i have a diff style arm, so i could be wrong.
^^^^^ hes right they go in the steering arms to make up for the extra space. Kind of hard to tell but those don't look angled, the bolt hole for the tie rod needs to be at an angle to the rest of the arm or your tie rod end will be maxed out at rest
