If it was the purple solenoid activation wire,it comes out of the fuse box on the drivers side--you coud snip it there and spice a new peice of wire in,and re-route it so it dont have to be inside the original harness..I have removed that metal conduit the starter wires go into on many 73-87 GMs and cars,the wirse often get roasted in that tube and burn up when they short out...I put the fusible link wires on a junction block and run them right to the positive battery terminal--that way I have only a battery cable and the purple wire left at the solenoid...had too many wire fires from them burning on the exhaust manifold ,once I put the wirig back to the way GM did it up until 1972,I have had no more wiring troubles..it was stupid to put wires in a metal tube an inch from a exhaust manifold & pipe,and not expect them to melt!..
