88 Blazer overlander
Newbie
I'm about to swap my 88 K5's 10 bolt rear for a 14 bolt rear. Is a 6 lug wheel hub still gonna do the trick when I go from 35s to 37s or should I go for something a bit more stout?
Thank you much, like I said those plans weren't concrete so I could find out what will and won't work so I can buy once and cry once. Any recommendations for driveshafts or U joints, I was think Spicer 1410s because logic tells me the same 1350s that I used on my 10 bolt would defeat the purpose of a 1 ton axle, same with reusing the same driveshaftsYou Will want to go to 17" 8 x 6.5 lug circle for 1 ton axles. The 15" might have clearance issues with the d60 disc brakes, plus much better tire choices for 17" wheels.
Your backwards on that . 1410 has more over 1350 .the 1350 u joint on the rear 14bolt has more range of angle, iirc, than a 1410.
