Wheel offset
Montanachris
Registered Member
Huson, MT
Have been looking at fuel wheels for my 1972 4x4 Blazer. I will be going with either 32 or 33 1050s and I'm wondering what offset should I go with to keep the tires flush with the outside of the fenders I hear the front and rear are different. Thanks a lot in advance hope you guys have a great weekend
If you go with a 17x9, you are going to want to stick with like a 0 offset or a 5.00 inch backspace. Not sure if that is going to clear everything though, I haven't done a set of wheels like that on an older truck. Most everything is a 9 with a -12 or 4.5 inch backspace.
17x9 4.5 bs will fit and look good but won't be "flush" in front.
If you want to even up the track width front to back you really need spacers or a wider axle out back. I don't think you'll have enough inside clearance to get much wider than an 8" wheel "flush" up front.
Most will agree that wheels look better with a "dish" or "lip" and that modern "front wheel drive" type high offset wheels look funny on older trucks but it's your baby...
As I recall now, I think 4.5" back spacing is what you're looking for. However, the stock rear axle is narrower than the front. If you want to even that up, you'll need to get 1.5" spacers for the back axle so that you can use the same wheels on both axles.
I am not sure what is needed. I just want the tires to be flush with the outside of the fenders. I have heard that the front axle is wider than the back axle.
So if I go with 1.5" spacers in the rear can I go with an 8" wheel
Here's a spec sheet showing a 4.5" back spacing with a 12" tire. This spec sheet is on a roadster shop chassis but I believe they built it to a stock K5 chassis.
