Whats the general consensus on wheel spacers? I would love me som HD wheels with some 35s but Im a gofast kinda guy and worried that wheelspacers carry that old scary spooky kind of trustlessness...
I have the same spacers. Excellent quality but expensive.I have spacers between my dually rims...1.5" thick I think, they come with separate studs....they mount to the factory studs over the inner wheel, then the outer wheel mounts to a different set of studs on the spacer/adapter. I have pulled 10K + with them and no issues. They are steel spacers, not aluminum for my application though.
It is meaningless to someone in the engineering field and tells you nothing about the actual material used. I want to see the material grade. 6061-T6 Aluminum is just as strong as many steels.a : a bar of metal
b : a piece of semifinished iron or steel nearly square in section made by rolling an ingot or bloom
c : a section of nonferrous metal ingot hot-worked by forging, rolling, or extrusion
d : a nonferrous casting suitable for rolling or extrusion
