Get an ANL fuse rated for the short circuit current rating of the wire, or 200% more than what you think you will ever run through it. You don't want a voltage drop across it but you also want to prevent unintentional welding. Spartan Systems sells a nice gold plated one with a nice fuse holder and a nice 1' lead for $20.
Grounds are easy to screw up. It is easy to end up with a floating ground. The best way to avoid it is to ensure the grounds are always substantial in size and have high quality terminations. Positive side is easier to troubleshoot. I try to have a 2/0 wire to the frame and from that same spot on the frame a 2/0 cable to the engine somewhere (I like to use the alternator bracket). Then 2/0 from the body (ideally, the cab) to that same spot on the frame. However, it is not always convenient to do that. And you can still end up with weird crap happening (ever notice GM always puts grounds to the core support so the headlights work).
Yandina makes several nice battery combiners at a decent price. It is basically relays/solenoids inside with a little bit of logic. It works great for charging the second battery or light loads (read: not winching). It is about twice the cost of a ColeHeresy 200 amp continuous duty solenoid. I used to use diode-based isolators but I don't anymore.
I started using BlueSeaSystems switches. They make a nice one that allows you to run off one battery, combine two, or turn it off altogether for about $25.
