Those aren’t compatible with an 85. Those have two ports..the one I have has three.
Is this Calif emissions equipped. My Federal 1985 sticker looks nothing like yours. i only show two vacuum hoses on solenoid. What is a diff pressure sensor and no vacuum to distributor.
Yup, Cali emissions.Is this Calif emissions equipped. My Federal 1985 sticker looks nothing like yours. i only show two vacuum hoses on solenoid. What is a diff pressure sensor and no vacuum to distributor.
If you where able to post a picture of the federal emission vacuum diagram, then you could figure out how to use a 2-port EGR solenoid in this system.
That might work with the vacuum t, I’ll give it a shot. ThanksThe only thing I can think of is to get the original GM part number, and then see if a parts person can interchange that part number. You may have to use a 2-port EGR control solenoid. If you use a vacuum-T to tie together port J with the EGR valve, and then keep vacuum port F as the manifold signal...that might work.
