Where do these go on the frame ?
I think those are similar to some @tarussell bought, I think they’re close to the crossmember at the rear of the cab.
Those do look similar to my brackets ( except the ones I got appear to be little taller for the deeper K-30 frame rail sections - hard to tell in this pic ) but I did not know that they came on a K-20 frame ?
I was under the impression that these were a Crew Cab K-30 only frame brackets - is your K-20 frame a Crew Cab ( which uses a 1-Ton frame ) ?
I was under the impression that these were a Crew Cab K-30 only frame brackets - is your K-20 frame a Crew Cab ( which uses a 1-Ton fraIta
Its a regular k20 frame. These came in a box with a pile of parts when I aquired the frame from a guy. I wasn't sure if it was just stuff in a box or actual parts for the frame.
See if there are any mounting holes that match up with these brackets near the rear most cab body mounts right about before the frame starts to kick upwards - that’s close to where they are on the K-30 Crew Cab frames.
