Where does it connect(vac line 350 tbi)
dudeiwin86
Houston, TX
Does the broken vac line in my hand connect to that fitting behind the throttle body(the one just in front of the. Distributor and to the right of that computer box in the pics below)? It's the line coming from the T fitting on the fire wall. I'm a tbi newbie. But diving right in!
I pulled the air cleaner assy off to change the plugs and wires And this is what I found(along with a cross threaded spark plug that I managed to repair without yanking the head. Thank you previous owner)
Thanks ahead of time
Idk lol. I have a carb, but try connecting it and see if it runs different, otherwise id say plug it lol.
Look at the last pic you posted and you'll see a vaccum port on the intake manifold right next to your EGR valve. That is where you line plugs into.
