Wanted Where to find AC Delco OEM Part Numbers List
clay1937
Registered Member
American Fork, UT
Where would I go to find a list of all OEM part numbers for a 1991 Blazer?
I've found a great source for NOS parts, if only I knew the part numbers to ask for.
Presently I'm looking for the part numbers for the 4 removable top weatherstripping pieces, and the 4 wheel well chrome pieces.
Thanks!
Thanks!
If you go to GM parts direct you can get your numbers . If they still keep it you can get it if discontinued you can retrieve the part number > Also you can buy a parts book off E=bay .I did and I might have your numbers you are looking for
I can get you those numbers in the morning. Expect to pay $1K + for OEM wheel opening moldings IF you can find them. They are discontinued long ago from GM. On the weatherstrips, I believe they are long gone also but I will check. GM Parts Direct is just a dealer that uploads their own catalog. Not always up to date and not always accurate.
Front Wheel Opening Moldings: LH 88891152
RH 88891151
Rear Wheel Opening Moldings: LH 88891147
RH 88891150
Top Weatherstrips: Refer to illustration
#1 15590455
#13 357490
#14 LH 358589
RH 358590
  • Jimmy Top.pdf
