where to get fusible links??
copedrake
san jose ca
i believe with the help of some guys on here i found out the problem.
does anyone know a place online or a store that i could pick up the fusible links that run in the wires from the starter to the alternator to the firewall?
it for a 85 sierra. I already looked at LMC's website without luck
i was going to try the dealership tomorrow, if they have it it will probrably cost an arm and a leg.
thanks for the help!
Most parts places should have a fusible link in with the fuses; you then just barrel-crimp it inline with the existing wire -- cutting out the existing fusible link, of course.
-- A
Yep, just about any parts stores will have them, we carry them at our store here in Fremont but since you're in San Jose try Winchester auto.
thanks for the help. i ran to the dealership afterwork and got it, $1 a foot.
it is a just a wire, i thought it would be the small black piece that is in line with the wire.
I got mine from Napa. Make sure that you got the right size wire.
IIRC you need 4 smaller than the wire carrying the load.
i.e. 14 gauge load - 18 gauge fusable link.
