Where to order shocks by measurements?
back pages of the catolog..
In the back pages of the catelog,there is a size chart where shocks are listed by extended and collapsed length,and bushing style..at least my 1990's Monroe book does....:crazy:
You can always look them up online with the manufacturers. Gabriel has their catalog in PDF form online with all the measurements and part numbers you could ever want. I know superlift does the same, I'm sure most do.
I know your application, Huge By Large by First Gen.
What lenghts are you after?
Skyjacker Has 300 apllications listed , depends on what your after.
This is by extended length/ travel / Gas or Hydro or Adjustable/ Ect.
Quick help may be Pro Comp Shocks / Lifetime Warranty/ @ www.summitracing.com
PN# EXP-34000, 20"-34" Ext. length Gas $33 bucks
PN# EXP-33600, 21"-36" "" "" "" $33 bucks
PN# EXP-93400, 20"-34" "" "" Gas/ ten stage valving $35
PN# EXP- 93600, 21"-36" " " "" """ """ "" @ $35
All shocks travel @ about 14 to 15''
You have to love shocks that come in feet , not inches, good luck.
:D BB06 :wink1:
Thanks. I ordered thru summit and got the EXP-932000. 18.8 inches collapsed and 32.8 inches extended. yeah 14 inches of travel should do. No more stretching the shock so far you hear a snap!!! They were $34.95 each.
That's what I was going to recommend (Summit). They have the pro comps listed for the travel, collapse, and extended lengths. Probably the other shocks too, but I only looked at the comps.
Yep they had a few different brands listed with lengths but some were still by application.
This is a problem when you have changed your application's mounting points on both the axle and frame. :doah:
