CrewCab59
A long time ago I bought a used set of 6" superlift springs from a guy at one of the 4x4 jamboree. I think he was a member here cant remember his name, anyways he swapped a cummins into his 1-ton crewcab and the front sat too low so he swapped the 6" springs for a set of 8" lift springs. I don't know what he did in the rear but with the weight of the cummins he was right around 6" lift in the front
That was me ,How could you forget ? Yes the Superlift 6'' springs sag to much and the rear was already set so I installed the 8'' fronts and it sets level .The rear I have 11 leaf rear pack with a steel 5'' rear block with air bags are used with using the 36ft GN trailer to help with the sway.The blocks have worked for 8 years
