I've searched and many say the Superlift and Skyjacker kits are the popular choice, yet others just add more leaves to their stock packs.
Well, I'm working on a budget to get a 6" lift to fit 35's for my crewcab, which will get a 5.9L Cummins swap sometime this fall. The truck has a 2" lift w/ 31's as it stands today.
I don't want to keep adding to my spring packs, I already have 6 up front and 13 in the rear. I'm aware the tallest pack I can buy for the rear is only 6".
My goal for this truck is to keep it a towrig, not necessarily meaning 100% street but somewhat 60/40 on/off road, such as sand washes and fire roads, no rocks so suspension flex is out of the question. And it must be capable of pulling 15-20k pounds safely so no lift blocks. I'm unsure at this point if shackle flips are safe, even if I use the 2.5" flip and 4" HD rear shackles. Not sure if this will be 6" in the rear anyway.
So, which 6" springs have the highest spring rate and how to make it a true 6" in the rear without blocks?
Thanks in advance
Thanks in advance
