chevyin
Glad you are gettin her done, and are happy with the results. Ya, its amazing when you hear new sounds in songs that you've listened to for years, aint it.
I did some research on Infinity's site trying to find cone excursion specs, but couldn't find them. With that being said, the cone moving an inch or so would give it an xmax of about 25mm. The average good quality subs today are in the 15-25mm range, so yes its quite possible your cone is moving that much.73k5blazer said:So I was out fiddling again with it (well, just listening really I couldn't help myself), so I've never had a sub in a car before (I guess my GTO has one, but's it buried under the rear shelf infront of the gas tank and it's pretty small), how much are those things supposed to move. When I crank up the volume, it still sounds really good (I was very anal about vibrations, I insulated and padded everything screwed into that side panel so I wouldn't hear any that nasty mashing/buzzing/loosness you hear so often in alot of cars with haphazzardly installed subs), but that sub really moves alot. A good inch or more. I realize that's it's purpose, to move air, but how much is too much. It's rated 350w, in a free air mount (which mine is) 175, the amp is 500@2ohms, 250@4ohm, and I'm guessing 125@8ohms which is how I have it wired.
I'm probaby just being paranoid....
As you know, for a speaker to make sound, it must move air. The more air it moves, the more sound its capable of producing, and of lower frequency (speaking in very basic terms here, other factors affect this somewhat as well). Two basic things restrict cone motion, the speaker's own suspension, and the air cushion created by the enclosure itself, both of which are always trying to bring the cone back to its centered home position. The more power (watts) you apply to the speaker, the more force is exerted to move the cone against these forces and push it farther (obviously). Therefore, more wattage moves the cone further. So the first step towards avoiding bottoming out your speaker is by not overpowering it given the enclosure it resides in, we've already discussed how running a speaker infinite baffle (or sometimes called free-air) drops its rated power handling... this is why. The second way to avoid bottoming out your speaker is by placing it in the proper sized enclosure (again, enclosure size/type and power handling go hand in hand). If the enclosure is too big given the power coming to the speaker, the air cushion created by the enclosure offers too little resistance, and the speaker's cone will be pushed beyonds its limits. So, placing a speaker within the proper sized enclosure and remaining within its proper power handling window should keep your cone's motion safely within its limits. But remember, improper gain settings can allow more power to a speaker than the amplifier should be pushing, so setting your amplifier gains properly also affects this situation (on the pwer side).73k5blazer said:Hey, thanks alot again. In playing with it some more and watching and listening, I think it's fine. I said an inch, but it's hard to really estimate how much. I couldn't hear any slapping or odd noises coming from it. Just crystal clear sound.
I'm sure most of the time, I doubt I'd have it that loud anyway. It was really cranked.
