Yeah! Just got it , thank you! So now what abt the ratio number for the axle? I heard that i should open the rear cover and count the gears on the bigest flang there? Is that rit?
Saw the location. I have watched videos of some guys over there. I sure do miss the sand.
Question about determining the gear ratio:
On my 72 C20, I jacked up the rear end, spun the wheels, and counted the driveshaft rotations for one revolution of the rear wheel. This told me I had approximately a 4.10 gear ratio. Later on I verified this when I sanded the surface rust off the tag on the rear end.
Shouldn't this work in this situation? It's a lot easier than counting teeth if you're looking for a quick answer.
What do u mean?
