I want to do a shackle flip. For better ride and better trail manners(for small tire burb anyway)
Current is 4" blocks on factory springs. Front unknown springs. I have front and rear 2.5" lift Rough country springs from a previous 3/4 ton burb?
Rear sits 1.5 lower at wheel openings I want to level it out.
The blocks have the pinion rotated up, which would be fine if I had a 1 piece CV drive shaft.
I have 2 piece atm. should I put a 1 piece cv drive shaft in a suburban ?
If not I need to rotate the angle of pinion down, How will the shackle flip effect pinion angle?
