reliability
I have no experience with the motor. But I will say this- Even nevada/new mexico heat doesnt exceed 140 degrees. So you still get a 40-50 degree temp differential. If a motor runs hot, it runs hot. Its pure and simple.
Just how many therms can air flowing past the radiator remove?
Its not as many as you would think, without the vehicle in motion. You don't need a fan when the car is in motion. You need a fan when the car isnt moving.
You can literally calculate the therms of heat produced by the motor, and the therms of heat that the radiator can dissipate, given the amount of air movement of the fan.
Add on caked mud, dirt, etc, oil coolers, trans coolers...the actual effective cooling is severely diminished. Deep in the forests out east, there isn't even a stiff breeze. Underhood temps are ridiculously high- manifolds, engine, hot air from the radiator, beaming sun..
And I kinda like to run AC.
Now.. If I were doing a swap, I might consider an ecotec LNF motor, with the remap. 290HP, 340ft lbs of torque. I think its less than half the weight of a SBC. Its intriguing. But Probably not as cost effective as a LSx motor of some sort.
