The dyno isn't going to tell you anything about the inside of your engine. You will be able to find out if it's in fact running too rich or too lean and that's controlled by TBI sizing, injector sizing, and dwell time of the injector which means CHIP. You will also be able to see the timing curve but once again this is controlled by the CHIP.
Should be able to tell HP and TQ which should give me an indication if I'm better then stock or not. Should also be able to tell if its retarding timing due to detonation. Along with fuel curve. Do these trucks run a constant fuel pump pressure? Give or take I was expecting 10-20HP over stock.
