I still feel like you could fabricate the wedges you need.
Here's an option: Buy 4 of these (~$25 total) and cut the width down to 2". Weld 2 on top of some 5/8" flat stock, drill 2 holes and you've pretty much got your bottom piece. Drill 2 holes in the other 2 to make the top plates. https://www.amazon.com/dp/B0F42MMVQ...rial&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWwy&th=1.
2 custom cut flat pieces is <$20:
https://www.onlinemetals.com/en/buy/carbon-steel/0-625-x-2-carbon-steel-rectangle-bar-1018-cold-finish/pid/9551?variant=9551_12_0&msclkid=5682e331d1ff1e6fd4ef8ac2601c270e&utm_source=bing&utm_medium=cpc&utm_campaign=[Rithum] [Shopping]- Top Materials&utm_term=4580634180087603&utm_content=Carbon Steel
I'm thinking that a slight change in height won't really affect skid plate mounting. You could potentially bend the end of plate or it might bring things into alignment as you tighten the bolts.
He would need 8 to do what he is asking for, but it will work well and can all be fabricated in a drill press by stacking and tack welding everything together. I wouldn't even trim the edges of the shims. Just offset the holes to one side if needed inside the frame. The short edge stackup is .743", only .007" short of your drawing.I still feel like you could fabricate the wedges you need.
Even if this was the main crossmember holding the transmission mount, I think you could drop one side 1" and leave the other side alone and the drivetrain would work fine. You'd just have some preload in the motor mounts. I do agree that a bandsaw is not going to make a perfectly flat cut through 2" steel bar.I know you both are very mechanically accomplished. I just want to point out that your driveshaft will be spinning 3 or 4k rpm and a U-joint is only going to tolerate so much wobble. These shims need to be a close as possible to identical. I think 0.005 may be a little excessive, but I don't think you're going to get anywhere near that with a saw. Hard decision, but I know that "good enough for now" usually ends up being more expensive down the road. I like the idea of making thinner wedges and addng your own spacers , that would cut material costs somewhat.....
I was assuming just 2 wedges on each side, for 1 crossmember is 4 total, but it's true you could start with 8 wedges and use a pair in opposite directions to make a flat block of the exact height you want. I've done this in carpentry with those packages of tapered shims they sell. You know, slide the top one left and right until you have the height you want, then trim to length (or don't)He would need 8 to do what he is asking for, but it will work well and can all be fabricated in a drill press by stacking and tack welding everything together. I wouldn't even trim the edges of the shims. Just offset the holes to one side if needed inside the frame. The short edge stackup is .743", only .007" short of your drawing.
