For my '98 Jimmy with 4.3?
O'Reilly shows 3 different temp ranges and I don't know which one to get.
(I don't speak efi very well)Id say 185*.. 165* can be considered the same as not having one in there at all opens up too soon and 200-210* is cutting it too close for my standards
I checked for the recommendations to use a Jet chip and they say to use an 180 degree 'stat.If it's still efi then you need 195°. Iirc, the lower temp t-stats will cause the computer to run in open loop something or other all the time. Anyway, it's not supposed to be good for it.(I don't speak efi very well)
andThe normal and most efficient operating temp for your engine is about 200 - 220 degrees. Therefore it's operating perfectly. Why do you think the thermostat is 195? It's because it opens at 195 degrees. GM and every other manufacturer did tons of research to figure this out and provide the best performance and longevity of your engine. They didn't just guess ...
Your truck is only overheating at about 265 degrees. 210? Completely normal. That's where mine runs.
A 160 thermostat will cause your engine to always run rich, because it will think it's not warmed up, so the choke basically will always be on, which will result in lower MPG, less power, and more emissions. In addition, the lack of heat will cause poor combustion, increased condensation in the exhaust which will rust it from the inside out, and finally the heat won't allow the oil to heat up which will cause it to turn to sludge. Finally, the lack of heat allows carbon build up in the cylinders.
Worst of all, your heater will suck in the winter time, especially with 0 degree weather!!!
All in all, the 160 thermostat won't be immediately apparent, but in a year or two you will wonder why all these other problems are cropping up.
Even with a 160 thermostat it won't fix your overheating problem. It will only cause other issues. If your truck is overheating, having the thermostat open sooner won't make your truck run cooler under load. It'll just run worse every other time.
What you need to do is flush your cooling system with a chemical CLEANER, check your water pump, check your cap, and pressure test the cooling system. If the cap or a leak is not keeping the water under pressure, then the block heats up and boils the water off the sides of the coolant passages. That puts air in the system, which makes it so that the coolant is not touching the block, and voila - over heating.
Most Chevy 350's operate at peak efficiency in the 200-212 degree range. You don't have to run a thermostat, but you are cheating yourself out of power and mileage.
From http://www.arrowheadradiator.com/pre...m_failures.htm
Most cars and light trucks since 1971 require thermostats with 192 or 195-degree ratings. Using a cooler thermostat (160 or 180 degree) can increase fuel and oil consumption, ring wear and emissions. On newer vehicles with computerized engine controls, the wrong thermostat can cause major performance and emission problems if the engine fails to reach the proper operating temperature.
The heat of the engine also helps prevent acid formation in the oil, burns off excess vapors, and removes condensation which turns your oil to sludge. In addition, the heat helps prevent exhaust condensation which will rust our your exhaust system sooner.
So, lower coolant temps are just causing more wear and less performance all around. You won't know until you go 100k miles and have to do a rebuild, when someone running a higher temp can just keep changing the oil. In the terms of MPG, you are throwing away money every time you fill up at $3.00+ a gallon.
I used to run a 160 thermostat in my cars when I was younger, but someone pointed out that engines have a thermostat for a reason and me second guessing over 100 years of research and development by putting a non-stock thermostat in makes me the fool. It turns out that the 160 degree thermostat was used for alcohol-based coolant. Am I really smarter than thousands of mechanical engineers who have tested thousands of cars over millions of miles? No, I am not, but I am learning!![]()
