handloader90
Building!
Personally I'd take the '68 K20,but both those trucks are not great for commuting ,they are both more of the "war wagon" type truck with a stiff ride ,low gearing,and will wear on your nerves after awhile..the '68 would make a good work truck,but no P/S or brakes wont make it good to tow with..and may even make daily driving risky,seeing how most vehicles have 4 wheel power disc brakes and you wont..
You'll need to keep a good distance behind other vehicles..
The M1008 might have the D60 and get slightly better mpg,but it is still a military truck..if you dont mind driving something that reminds of a deuce and a half daily,it would be OK,but to me,they are overpriced--half the value is in the front axle ,T-case and Th400--I'm not so sure they had any beefier frames than a civilian K5 had..if the M1008 was priced the same as the '68 is,it would be a better all around driver,but it isn't a pickup truck either...some things just cant be hauled in a K5 like a pickup..(Quads,Fridges,Stoves,Lumber,garden tractors,etc)..
I've seen a 1008 frame in a truck that had the bed pulled off and they are most definitely beefier than a 1/2 or 3/4 ton truck.
Not sure if it's beefier than a K30 though.
Just something I like about driving an older vehicle. I would drive my 66 far more often if I wasn't trying to limit the miles - for both insurance and preservation purposes.
