which weld on repair kits?
Chrisblazzer89
Massachusetts 02301
Ok I have a horrible frame crack and I need to buy a repair kit.
Which one should I buy the
ORD repair kit for $75
or Blazen off roads kit for $70
I believe they are both about the same. If you want the best protection ORD also has a bolt on kit and getting both is the answer.
Pay attention to the welding instructions as you are supposed to weld only certain areas.
Chrisblazzer89 said:
Nvm guys I just ordered my self a weld on frame repair kit, and a Bolt steering box brace from ORD it will be here on Apr/27/07 :D
Hey everyone,
In case you didn't hear...Chris is now PAYPAL verified! :haha:
Good job on getting both the weld on and bolt on kits. You won't regret it.
Manny
MNorby said:
dito getting both.... trust me, I know.
I wanna know more about your story- please. Did you have just the bolt on or just the weld on when you had problems? Or neither?
I put on the weld on kit when i lifted the truck- later I boxed and sleeved two bolts of the steering box. The other two weren't done cuz I'd have to rip it off if/when I do the 52" or 56" spring swap.
Boxed and sleeved- Had to work with the steel I had on hand.
Pics and some story can be found here
http://coloradok5.com/forums/showthread.php?t=184928&highlight=steering+brace
