Just bought this '86, p/o put a crate motor in it with a carb. Which wire to h/u to + choke? The green wire and the tan/black both have 12v with key on.......does it matter which one to use?
I thought since it is related to a specific year this would be the better forum to post in. I found the factory brochures show that it was carb'd. A wiring schematic would be nice so I can find out what the tan/blk wire was for. I will keep searching.
Thanks, neither is constant. Both have 12v when KO only. Was wondering if either one would effect the electronics in the distributor if hooked up to the choke. Sounds stupid I know but had to ask. Will be rebuilding the carb to get the erratic idle/ stumbling while holding rpm up.
