Leper
locker 300.00
6 sets of spare stock axles 50.00 a set(and used them all)
SUPERSUB87 said:and how much did that pretty thang run ya? ive been searching for a 60 for so long and i havent had any luck so the pimped d44 is sounding better every month. but that wont get me in top truck challenge. <---( hopefully in the future.)![]()
SUPERSUB87 said:i know most people have dana 60's, but who has spent some a chunk of change making their 44's (or 10bolts) tougher. Also, how much did you spend.![]()
I have not spent tooooooo much yet on upgrades to the 10b but I have invested in gears, bearings cross over steering and 8lug conversion over the last year.(Mostly to match the back 14b) I am running 33's and will wear them out before going larger. I know it is inevitable that I will(even with the 33's) that I will tear apart the front at some point and so I will plan to get a 60. I think it is a waist of money to Bling out a 10b. if you are going to wheel hard enough that the 10b needs to be strengthened it is a waist of money and you need a 60.
BTW I have 600 to 700$ into her alone with the cross over. but I love throwing money away![]()
Well it lasted longer than a year then hahaWell Now it is broke. so off to throw more money down the drain on a 10b.
This thread is from a year ago but he was asking just how much people had spent on beeefing up their 44's or 10 bolts. think it was more of an observation on how many have actually put alot of money into themWhat size tire do you want to run? What type of wheelin'? those are the thing that decide if you need a 60.
Well now i know its limits...ssped started it.
I was pricing axles and looking at what the quality/strength difference is in cromoly shafts and popped across this thread. I have been getting a range of prices so what is the difference? so you picked up that other chromo side then huh. i was thinkin about it too but just going 3/4.
Sorry dug this one up.I was pricing axles and looking at what the quality/strength difference is in cromoly shafts and popped across this thread. I have been getting a range of prices so what is the difference?
As I said I like throwing away money. But not that much.
, I know) and put it back together. Used the same gears, but they didn't look too bad so we'll see how long it lasts. The truetrac is definetly more beefy then the open diff, so it'll either be the gears or the shafts to go next i guess. Here's a question though, on my front axle the pinion has a lot of slop in it. It must have loosened up. Is this just something I can tighten back up or would this be the bearings wearing out?
