who here is running 63" rears
How much lift did you get in back from that setup Ryan?
Well my previous setup was stock springs & shackles with an ord 4" shackle flip. The back sat a little high especially after I swapped bodys. Then I swapped to the 64" springs and lost an 1" of lift, so the truck then sat level.
I have since added a zero-rate because the 52" spring swap in the front raised the front end a little more
