Who is towing how much with what gas motors?
I tow with a 32 foot class a motorhome powered by a Ford 460. Dry weight is 14,400 and GCWR is 25,000. I have towed a 4500 pound jeep on a 2200 pound trailer with it. Best gas mileage was 6mpg and worst was 3mpg in a windy storm. I loose anywhere from 10 to 20 mph going up hills depending on the grade. It has a Dana 80 rear with 5.13 gears in it.
3mpg? So you sat idling at a rest stop for 45 minutes, drove a few miles, then calculated fuel economy? Seems awful low...even for an underpowered/overtaxed Ford 460.
Roy
I have a 2002 1500hd w/ 6.0 I put a volant cool air intake , superchips programer and dual exhaust on it I think from the factory they are a little restricted in their breathing. The most I ever towed with it was a 86 4x4 burban on my uncles trailer he said it weighs about 2200lbs not quite sure what the burban weighs but with the programger set for the towing mode I ran 75 on the highway with no problems the hd has a trans temp gauge and it never came close of getting hot and the engine satyed cool I did put in some of that water wetter in the coolant not to sure if it helped or nor but I ran with the a/c on most of the time from here to Tampa Florida about 1300 mile no problems I think its the best truck I ever owned
I guess I'm the only one that tows with a 4.8L. Its an 06' crew cab 4X4 and I'm not saying perfect, but if does the job the two or three weekends
a month that I pull my 1 ton blazer. A couple of air bags in the rear for the squat factor and it's good to go. And the 20-22 mpg when I'm not pulling is great too!!!! Jus thought I would give props to the little motors that could.
I tow with a GMC 2500 4x4 6.0L and 4.10 gears. I have pulled close 10,000 lbs with it over rolling hills for about 150 miles 10 mpg and held 65mph on all but the steepest hills. I think the heaviest load I have had on it was a pair of one ton pickup's, trail rigs, on a 36' gooseneck. Still had the power to pull but the springs were asking for help at that point.
Driving my blazer, stock k5 with a tbi350 700r4 33" at's and 3.42 pulled a 2000# dump trailer with 6500# of gravel. Total weight, k5+trailer+gravel=14800#:D
Do the tube chassis and build light, Yank that 500 and do a warm up on it. Swap in some injection and the automatic of your choice. Find an old body Chevy and dump it in there. Best of both worlds!
So I'm gonna do a parking lot motor swap every time I tow my junk somewhere and wanna wheel?
