Who runs 44"s
JK5 said:
Why aren't you runnin' yours??? They don't fit???
F"ing AGR steering box took a crap :mad:
it has been in every thing but rocks, iowa is not known for rocks.
i am planing a trip to the cliffs and rockport sometime in the spring.
i do alot of steep muddy,sandy,washout hill climbs and do alot of deep mud.
before i took the doors off i have had standing water in the cab deep enough
that it covered the front seats :eek1:
thanks for the comp!
No prob, dude!
JK5 said:
I had issues with mine...until I bumped-up the pump pressure.
What happened???
won't turn left very far, also has a spot where you can turn the wheel a complete turn and nothing happens, I got a 2 wheel drive box I'am going to put on with hydro-steering
Mine has issues once in a while...I may be going full-hydro over the winter.
The hydro-assist will help.
this is how mine sits right now ....still gotta move brake lines a little more forward so they dont limit my travel and fab up my shock hoops.. and then i start on the rear 57 swap and then more trimmming haha
Basing,
What are you running for lift front and rear? You say your planning for 57' springs out back but what do you have in there now? Have you moved your front axle forward, I'm guessing so.
Anyway, it would be kool if you could give a little more info on the BEAST!
Thanks
Matt
