I haven't used aftermarket braided line much. I bought some to do and oil cooler then realized it was the wrong size. I kept it to use later. I have some Summit racing branded and some Jegs branded. These are both screw on straight -6 AN (3/8ths). The largest drill bit I could fit in the Jegs was 13/64ths while the Summit brand fit a 1/4 easily maybe even 17/64ths. This is a pretty big restriction, I measured a brass barb 3/8 fitting 5/16 drill fit easily.
Fluid restrictions cause heat, something I would like to avoid, since most if not all will be cooler lines.
So has anyone else noticed this and what brand do you like best.
Also what is the best method to get the collar over the braided hose?
Summit on left Jegs on right
