Who's got a slick gear oil filler/pump method?
I like that drill one. Thats cool. I have a screw on pump top (like for lotion) that I got at the Zone years ago and it pumps good. Screws right on the gallon gear oil bottles.
It pumps the lotion on its skin!
pvfjr said:
Here's where Kert made the best one I've seen. There used to be a pic, guess it's gone now. Kinda useless without the pic.:crazy:
http://coloradok5.com/forums/showthread.php?t=184438&highlight=rejected+ring
I'll get a pic up some time again.
Basically an air tank on end. Valve and hose on the bottom. Fill port on the top made from a large NPT fitting. Fill with fluid and then charge with air. The air drives the fluid out the bottom valve and hose and into whatever it is you are trying to fill.
Use an air coupler threaded into the large NPT fitting so you can leave a positive air charge in the tank. Dont' need to much pressure.
Sweet, I'm glad you saw this. I was starting to forget what it looked like. :confused: I just remember it was the best thing I've ever seen for something like this. :bow: That'd be cool if you got the pic up, I was wanting to show it to a buddy of mine.
