You need a raised steering arm. The should be a slight angle on the drag link , not the major angle.
For a quick temporary fix you can adjust your current drag link, make it longer.
drop pitman does 2"-3" lift only.
more than that needs raised are NOT the drop pitman arm .
and do not try and use both at same time with only 4" lift.
if you ever talked or planed on dana 60 swap then maybe that's why . as drop pitman are would still be used .
but yes it will work and its just not the 4" you need .
also the taller you get with push/pull steering the worse it gets . that's why 4" or more is best to do crossover if you want 100% steering .
lifting it gets the angles and travel all messed up even with correction parts its still not back to 100% range of motion of stock hight and setup .
also as said have you played with the adjustment of the drag link for best range of motion ?
I have not played with the length yet. I was so focused on getting the wheel straight when driving straight ahead.
Guess ill be going cross over sooner than planned.
You need to adjust the draglink so the steering wheel is straight, that will get you lock-to-lock turning (on the street anyway).
