snipepod
TPI-Vortec-
- Joined
- Oct 7, 2004
- Posts
- 18
- Reaction score
- 13
As part of my 1976 K5 restoration, I am replacing my 70amp 12SI alternator with a CS144 140amp unit. I need to upgrade my wiring to get that added power to the proper spots. I have removed the engine wiring harness and cleaned it up as part of the restoration. It gave me the opportunity to strategize on what wires need to go bigger and understand GM 12v Power distribution. Inside the engine harness is this 4 wire junction.
The wires are:
#One is 12ga and comes from the battery output on the alternator. It is the only wire connected to the BAT connector on the alternator.
#Two is the alternator's voltage sensing feed. Also looks like 12ga.
#Three goes to the firewall the bulkhead connector via as PIN 2. This looks like the main power to the interior of Blazer. In think 12ga also.
#Four goes to the exposed junction block on the firewall. 12ga also? Here is a picture of that... Notice the fusible like at its end.
This distance from the 4 wire junction to the alternator (Wire one and two) is about 30 inches. Wire four is also about 30" to the expose junction block.
There is a lot going on here, but my fundamental questions is why did GM just not run the two alternator wires all the way up the harness to the exposed junction block and then distribute to the entire truck from that point? What was the thought process to only going 30 inches away from the alternator and distribute power and attach the alternator voltage sensing there?
GM has smart designers, just want to understand before I modify.
The wires are:
