Why did GM use Torsen bars?
Hummer H1 was the only truck, sonce 1972 to come with rear leaf suspension. the H2 is just built on a K2500 chassis, so nothing special there.
The H2 has the Tahoe coil spring layout with links in the rear. The 2500 has leaf springs , like other pickups, even when ordered with quadrasteer ( which is dana 60 ). They're tested every year by all the mags /forums/images/graemlins/k5.gif
They used them on 60-62 suburbans---I dont have firsthand knowledge,but I heard they liked to snap a lot.I prefer good old coil and leaf springs,although I must say I put my old VW beetles through hell on and offroad and I even moved them up a spline or two for a poor mans dune buggy lift kit(not an easy job by the way!)and I never broke one--but beetles dont weigh much either!.I did have one break on a 68 dodge corenet 440 wagon--it broke while the car was parked--we heard a bang and saw the car leaning to the drivers side,I thought a tire blew out,but the torsion bar had broken!. /forums/images/graemlins/eek.gif
Dunno, my k2500 rides a lot rougher than my friends yukon XL does.
Put half your rated payload in your truck and I bet it rides just as nice as that Yukon /forums/images/graemlins/thumb.gif Trucks with extra capacity for a big load are going to ride rough when empty no matter what suspension you have /forums/images/graemlins/histerical.gif
All 1960-62 Chevy and GMC trucks including the suburban were torsion bar front suspension (2wd only). I have seen and driven alot of 1960-66 GM trucks as well as hang out on all the 60-66 Chevy GMC boards and email lists and never seen or heard of a wide spread problem with broken torsion bars, even when heavily abused with a 900# V6 motor sitting on them. Now heavy abuse and extreme rust from the midwest or NE might make a difference.
The 60-62 trucks have always had a better ride than the 63-66 models with coil springs (when comparing similar trucks) but parts are harder to find and more expensive for the torsion bar front suspension (like $150 ball joints /forums/images/graemlins/yikes.gif).
I'd say your right about the rust being the demise of the torsion bars up here--or perhaps the mounting points on the frame rotted out--.Not to mention our potholes!
A friend of mine had 2 nice suburbans,a 1966 with a tailgate and liftback,292 with 3 on the tree,2wd,and a 2wd 1962 panel with barn doors,a 261 straight six,with a clark 5 speed--factory!It had the torsion bar suspension,and I'm fairly sure it was a 20 series,3/4 ton.It did ride much better than his 66 did.I bet both of those trucks are long gone thanks to our climate and salt now. /forums/images/graemlins/frown.gif
i have a 2001 1/2 ton 2wd and its got coils...also has two bars that go from the front crossmember to the framerails, but they dont have anything to do with the suspension
There are others, those are just the examples I can think of. I believe the newer toyota trucks use coils up front with IFS. I don't much care for IFS so I don't research it very much at all....but I know there are plenty of rigs on the market with a arms and coils.
Toyota uses coilovers up front on their trucks, for the same reason chevy uses the torsion bars. The 2wd is just a 4wd suspension without the 4wd hardware.
I believe the new F-150's are coilover as well.
