y5mgisi
1 ton status
Yep. Thats a power wagon. Its got a factory winch, sway bar disconnet, and lockers.
Whats the motor looking thing on the left side of the sway bar? Is that a factory disconnect? And the Guy with the MJ was NOT just casually driving down the dirt road. I've rolled enough old play vehicles beating them to know he was doing a good clip and any bent steering arms were probably due to the accident, not the cause. The big Z is a bad idea for sure though. Even if you were able to do it, as you've already figured out you cant, you still wouldnt be able to run the sway bar because the steering arm end would contact it. It was a good thought though. I'm still working on a way to do crossover with a sway bar. I know its possible but just not with the factory bar.
If you take this type of steering and apply a bit of normal wear to each of the ends then turn the tires you will begin to see why it isn't the greatest setup in the world. Yes it works there is no denying that.
What happens is that as you apply very minor amounts of turning force the slightly worn drag link and tie rod ends rotate a bit. What this results in is actually a little piece of a turn at the steering wheel won't equal any turn at the tires. All of the turning force is put into the minor rotation of the tie rod and drag link. After the ends have rotated to the end of their range only then does the steering effort make it to the tires.
It basically becomes vague in it's response. Then there are all of the other issues with actually being able to connect the points like has already been discussed.
HOLY FRONT SPRINGS BATMAN!!!!!!
I see very many thin springs. Bet it flexes like mad. Reminds me of National Spring's products back in the day.HOLY FRONT SPRINGS BATMAN!!!!!!
will they flex at all? what the idea behind that there?![]()
yeah....no... Theres a reason why its not done that way.
That draglink looks like it came straight out of the ScarySteering website: http://128.83.80.200/taco/scarysteering8.html
Ford uses a a setup similar to this, but the draglink is straight, as it should be. Just think about the forces on those bends everytime you turn the wheel.
So it seems some of you are arguing that it is unsafe because of the bend in the draglink? ORD sels then that way and no one seems to have a problem with those yet. Im talking about essentially taking a ORD bent draglink, shorting it, and attaching it to the tierod. Still unsafe or acceptable?
Umm... my ORD Drag Link has bends in it...![]()
