joez
84_Chevy_K10 said:Read the sentence again. Not every trailer in Illinois is required to have brakes. I think it's a 2,000 lb limit. But if it's required to have brakes, it has to have brakes on every axle.
Some 7,000 lb car trailers I've seen have brakes on only one axle. They cannot be sold in Illinois as they're illegal.
No, its not. Brakes are not required on all wheels, only one axle. And thats only if the trailer exceeds 3K pounds. It must have one independent braking axle and if the trailer exceeds 5K pounds it must have a breakaway setup.
Every trailer of a *GW of over 3,000lbs. must be equipped with brakes when operated upon a highway. Such brakes must be so designed and connected that in case of an accidental breakaway of a towed vehicle over 5,000lbs., the brakes are automatically applied. Drawbar or other connection shall be of sufficient strength to pull all the weight towed and shall not exceed 15’ in length. Outside a business, residential or suburban district, or highway, no vehicle shall be towed on a roadway except by a drawbar and each such vehicle so towed shall, in addition, be coupled with 2 safety chains or cables to the towing vehicle. Chains or cables shall be of sufficient size and strength to prevent towed vehicle parting from towing vehicle in case drawbar should break or become disengaged. Special permit required if combination exceed size limits. Brake hookup required if vehicle towed is over 3,000lbs.
Nowhere is it specified that its required on all wheels. HERE is another listing, and the states that require it on all wheels are specified. Illinois is not, nor has ever been one.
