chevy_addict said:Rene, what brand/model of wd hitch do you have?
Dave
It was a Reese, and rated for 10,000 lbs with the WD set-up. I no longer have the reciever hitch though, and can't recall the model number.
Rene
Dave
BadDog said:And I still stick by my caution on working a shackle flipped truck at or near full capacity. I think the points made about changes in behavior between compression and tension shackle are simple physical facts and do not seem to be debatable. If you take an "n" rated truck, change it from tension shackle to compression shackle, you have change a major component of the suspension to have very different characteristics than the factory setup on which the tested/engineered rating is based. That does not mean you can't still work it at that level successfully, doesn't mean that at "n-m" load it is going to fail catastrophically, but it DOES mean that you have changed it's behavior at a given weight AND (IMO) it is clear that you have at the very least lost some of the "safety factor" and ability to control the load. I believe these are all clear facts in evidence and I do not believe there can be any controversy over them, so the only point of discussion is "how much" and "does it matter". Those questions are difficult to pin down.
