Re: Why won\'t my 4 speed go into gear?
The rear most fork is for reverse. It honestly sounds as though one of the forks is not in it's slot properly. I would remove the cover and make sure it's lined up properly. Remember that the reverse mechanism has to be halfway between in and out to line up properly. Once the cover is off it can slide freely so it would be easy to mis-align. Once the cover is off install the shifter and make sure it is halfway into reverse before putting the cover back on.
Rene
Rene
