wider 14-bolt?
chiefheaphy
East MASS
Is there such thing as a wider 14ff that matches up with the DRW front 60 and if so what can it be found on?
3/4 ton or 1 ton dually, I believe...
I just found a 60front and Dually rear in N. Billerica. The rear is real narrow. The way the rims are make it look wide.
Need any parts BigBlaze? I have a blow 10 bolt rear and good 10 bolt front. 4 inch front springs, 4 inch blocks. TH700. Np208. close to junk 33's on good alum. 6 bolt rims.
junk yard hunt
I love junk yard hunts. Looks like I know what im doin sat.
G30/1 ton chevy van from around 77-91 or so I assume?
I'm pullin a np208 and th700 and my 10 bolts in a couple weekends if you need any partz.
Dually rear 14bff is wider than VAN G30 14bff which is wider than SRW 14bff which is wider than Cab and chassis 14bff :D
What you saw as narrow from a dually is probably the Cab and chassis 14bff.
Is it 58" from WMS to WMS (wheel mounting surface)
