Cpop305
Registered Member
Is there any good reason why I shouldn’t put spacers in the rear to match the front , really not a fan of the width difference. Opinions? Solutions?
It’s a 77 k5 with a 12 bolt . I have just always gone back and forth about how to resolveMy '05 Silverado came with some spacers on the rear when I bought it used. I didn't notice until it was time for new tires. It's fine, 8 lug, full float, doesn't bother me. On a lighter duty axle it might bother me.
On my K5 when I swapped to 1ton axles I used a later model rear, AAM 10.5. Matches the front width and is super strong without a spacer.
It all depends on what you have planned for the truck. You can get lots of widths different ways. What truck are you talking about, 1/2 ton, 3/4 ton, 1ton?
You do realize running spacers and changing the wheel offset both change the leverage on the axle bearings in the exact same way by moving the center of the tire. The only difference is the load path on the spacer has more components to fail.But if you had different off set for the rear...
Keep in mind spacers put more leverage on the axle bearings.
hmmm shouldnt be THAT wide... wonder if yours came out of a cargo van??? should have been the only ones that wide.I actually think it looks a bit weird. I have a 14SF that pushed the wheels out to about the same width as the front, and the tires JUST don't fit in the wheel well. The fronts don't look the same. Stock wheels and tire width (10.5").
Minor annoyance, but it throws a lot more junk onto the side of the vehicle too.
Not noticed any difference in turning radius. Not saying it isn't there, just not a large enough difference if it is, for me to notice.
Did not know those wheels could fit on a 15x8 wheel..hmmm shouldnt be THAT wide... wonder if yours came out of a cargo van??? should have been the only ones that wide.
im running 35x12.50 tires on a stock steel ralleye wheel... 8 inch wide. outer edge of tire is approaching outside edge of fender... but is still inside. no problems with extra mud flinging on body or windows, and they tuck perfectly. i have something in the range of 3 feet of articulation right now and have not had to cut or modify the rear fenders at all. no tire rubbing. (the front with a stock 10 bolt and the same tires/ wheels was a different story -trimming happened)
well, the contact patch on the ground may not be 100 percent optimal, but ive not had a reason to switch wheels yet. Photos are probably mixed tires on the same wheels over the years.Did not know those wheels could fit on a 15x8 wheel..
So 35x12.5 should fit on a 15x8 wheel as well correct?
Those are one I had on mine, if I remember correctly.I've been running these spacers on the rear of my burb for the past three years with no issues View attachment 443804View attachment 443805View attachment 443806
