Will 2000 4L60E Transmission Bolt up ot 1971 Transfer Case?
beachblaze
Registered Member
Southern California
6 years ago I installed a 2000 5.3 vortec w/4L60E transmission in a 1987 4wd full size Blazer. Now I am moving the motor and trans to a 1971 Blazer (currently 4 speed manual). I would like to use the 1971 transfer case if possible. Will it bolt up?
The manual t case is 10 spline and the 4l60 should be 27 spline so no, not without a input shaft change
He is going to need more than a input shaft changed. He has a late model transmission which has the newer 6 bolts output housing. To make it fit a factory NP205 to TH350 adapter and sleeve, he is going to need the Adavce Adapters tailhousing adapter.
