Will a 2003 2wd 10 bolt 6 lug that came out of a 2500 fit under my 1995
Mudaholic_bronco
I'm about to buy that rear end and would like to know if it will fit under my year truck. And what do I have to salvage to keep the disk brake on the 2003 rear end . Mines drum
if its a 2500 it should be a 14bff minimum. if its a 10bolt, somebody swapped axles for a 1/2 ton model
Agreed, or a 14SF 6 lug.
I would think the width is similar but don't know for sure. Put a tape measure on it WMS to WMS.
Okay so that rear was missing the spider gears so that was a no go btw I appreciate the help guys . My new question is will the 1992 10 bolt bolt right in?
Okay well the 10 bolt they had was actually a 14 bolt of a 1993 so back to the original question will that one fit I think it measure the same from outside leaf spring to outside leaf spring the is 50 inches
Perfect
Welcome to the never ending quest of building your truck!
Lol heavenly is a solid axle swap ! Just need befriends to help but ain't much in Miami that will take beer and good friendship as payment
