will an early 73' to xx' dash cover fit in an 89'
rdn2blazer
1 ton status
- In Memoriam -
So Cal.
I need an early dash cover that does not have the VIN cut out, need to know if a early dash pad will fit my now 74' registered, 89' burb :D.
gm relocated the vin from inside the driver door to the top of the dash in 1977. Find one from a 73-76. The dash pad is also the span of the entire dash and your 89 is squared off on the passenger side and the early styles are rounded. If that matters.
