will hubs of a 10 bolt work on a 44???
If you're referring to the hub/rotor assembly it all depends on what year D44. There are two different spindles and the break is mid 76 and earlier and mid 76 and later. The only difference is the inner wheel bearing is larger (2" ID) on the later spindles and IIRC (1.75" ID) on the earlier spindles.
What he said^^^^^
Ira
