jgr
Registered Member
I'm brand new to WinALDL and I need some help reading the output. I've attached the log files and would greatly appreciate a second opinion.
I'm trying to pinpoint why my 90 K5 is idling rough & eradically. It also takes about 4 seconds of cranking to get it started when it's cold. It's been completely tuned up, checked for vac leaks, and has the following new parts: Distributer, IAC, MAP, TPS, TB gasket.
WinALDL is giving me a steady "CLOSED Loop Flag", "Old High Gear Flag" & "BLM Enabled Flag". I also get intermittent "Rich Flag" and "DRP Occured".
My coolant temp is running about 182 degrees but I thought this engine used a 195 degree thermostat. Is this the source of my problem?
Thank you much.
Jon
Thank you much.
Jon
