GsxrMike
Well I was wondering about that strenght issue. Where will the weak point be? I would like to build a receiver into a bumper that goes from frame rail to frame rail front and rear.
The receiver tube itself is gonna be the worst, as you have a foot or so of a level in the form of the post going into it and then the cradle... basically the distance from the fairlead to the front of the tube.
Actually -- and remember I never completed my engineering major -- you've also got some vertical forces at work there, plus twisties (torsion.)
Even if the crossmember is nice and solid, the receiver tube will need some serious gusseting, and the post on the cradle itself should be sleeved and welded good ... the premade ones are prolly only .187 wall, and that can bend with enough force applied =))
Scroll waaay down on http://www.ramsey.com/accessories.html and you'll see
http://www.etrailer.com/mm5/merchan...re_Code=E&Product_Code=6495&Category_Code=FMH
http://www.warn.com/truck/mounting-systems/winch_carrier.shtml
You get the idea.
-- A
Very nice! Can you slide a hitch into that receiver tube?
Slides in and out with a 3/4" grade 8 bolt holding it in place.Alright big blzn I need more pictures now. I got a winch and I am still thinking about the receiver for front and rear.
