Windshield wiper motor
rwick3142
Raleigh
Hey Guys, having a hard time with my 1991 GMC Jimmy windshield wipers. They function for about 20 minutes, then stop. I have replaced the motor, there is no binding in the wiper motion, and nothing gets hot. This new motor seems to be too weak and I can help it so it moves the wipers. Seems like only 1 speed is operating. Would that be the switch as a problem? And I am looking for a better motor than this China junk, any suggestions?
What was the reason you replaced the original? Was it not working or working hard?
They really don't work very well unless the windshield is wet. I think the weak motor is why many choose to run the short factory length blades instead of the longer ones that do fit. You should be able to plug in the old motor (loose piece, not reinstalled) and see if it has 2 speeds.
Somebody went down the path of putting a relay on the wipers, but you'd have to search to see how that worked out. Likewise with the efforts to adapt GMT400 motors.
My first inclination was that the original quit. I ordered the new motor, installed it, and then bench tested the old motor and it ran but weak. I may try rain x to "lube" the windshield, and go back to shorter wiper blades. I need to replace the wiper arms anyway, the nozzle for the cleaner is long gone.
First, clean all of your grounds. Electrical stuff doesn't like bad grounds.
Then I would be looking at the switch itself and wiring between the switch and wiper motor to make sure there are no spliced wires or corroded terminals.
I cleaned all the grounds, and actually ran a fresh ground wire from the motor to the firewall ground post that the previous owner installed for a stereo system. I have put relays on all the power windows, and that worked wonders, but I can't seem to find any technical doc on if/how you can do that to the wiper motor. I am going to start with smaller blades, see if the less resistance makes a difference with rain x applied.
I am running a Napa reman and its worked fine for 3 years. Make sure you lube the wiper arm transmission joints well.
Is the delay module still installed? You can unplug both ends and plug the together w/o the module installed. Module is under the steering column.
Remove module and test should have 2 speeds hi and low
