Stomis
Professional Amateur
Ok so why is everything so friggin expensive for windshield wipers?!?!?!?!
87 no tilt, with intermitency, on the column.
First lemme explain the problem. Windshield wipers only work on high. I get no fluid (although I'm pretty sure this is due to a bad pump because I hear it try to click on), no intermitency, no low. The wipers do not seat when you turn them off.
Now if I leave my wipers on high for a little while the low setting will magically work but still no intermitency and no returning to "home" when I shut them off.
So far I've replaced the magic $70 black box under the column and that didnt make a friggin difference. I really dont want to fork out the money for the column switch... Could the problem be in the motor or is the switch the last place that could cause this?
Anything else to look for that I'm missing?
